TwinTurbo.NET: Nissan 300ZX forum - Re: White smoke...search wasnt much help
craigz96tt
on March 20, 2010 at 9:05 AM
posted by Paulym1111
on March 19, 2010 at 04:46 PM
I also say coolant is the culprit. Easy to see if coolant system is
sealed. Run car up to normal operating temp and after you shut
it off try to squeeze top radiator hose with your fingers, if you
can compress it your system is not sealed
Paulym1111
16:46:53 03/19/10
Coolant leaking into intake...
draker
17:28:41 03/19/10
not a coolant issue...I also have a backfire. Anythoughts? (n/m)
Paulym1111
19:02:25 03/19/10
Why are you ruling this out? (n/m)
draker
23:26:51 03/19/10
spark plugs after about an hour of running (all black)
Paulym1111
08:28:43 03/20/10
Re: White smoke...search wasnt much help -
craigz96tt
09:05:09 03/20/10
i really dont think its a coolant issue
Paulym1111
09:47:13 03/20/10
I have a 555cc EPROM but 550cc injectors.
Paulym1111
10:20:07 03/20/10
figured it out...i think
Paulym1111
12:34:44 03/20/10
Re: figured it out...i think (n/m)
draker
14:19:27 03/20/10
Interesting...
draker
14:23:25 03/20/10
White can be fuel if there is just raw fuel pouring through
na300zx (OH)
19:24:56 03/20/10
Good to know! I've never had that issue. (n/m)
draker
03:25:48 03/21/10
Re: Interesting...
hunterdg
02:09:57 03/21/10
Tip- With injector(s) replace always pressure test the >>>
ZUL8TR
07:39:41 03/21/10
